- November 2024 News Summary (News:1)
- Destiny Hints and Tips
The Icon Bar: News and features: SunBurst hints, tips and walkthrough
Hints & Tips
    not be destroyed.
Walkthrough
  1. Set course to Research 1
  8. Kill Death and Famine.
  10. Destroy War.
    Hyang.
    the Hyang.
  23. Head back to Oasis.
  27. Catch the Hyang again.
    ships!
  31. Head to Nimbus.
  33. Upgrade!
  36. Destroy the 4 'spikes'.
  42. Head to the launch site.
Cheat codes
CASH5000 extra credits.
SunBurst directory.
  (15:58 11/12/2000)
  Owain Cole (12:54 12/9/2001)
Dave
Owain Cole Message #87879, posted at 12:54, 12/9/2001, in reply to message #87878
